INSTALLING AND CONFIGURING IP ADDRESS ON HWIC-4ESW INTERFACE
Answered Question
Dec 29th, 2008
Hi everybody,
compliments of the season.
I added a four ports interface card (HWIC-4ESW) to our router 2800 series router (2811).
when i tried to configure an ip address on the fast ethernet 0/0/0 interface, it was showing me that i may not configure ip address on L2 link.
please what does this mean.
And how can i assign ip address to the interfaces.
The interfaces were installed so that I wouldnt have to use sub interfaces to link some of my networks.
I prefer using physical interface instead of sub interfaces which was why we got the extra interfaces but without being able to set ip address on the interfaces the purpose will be defeated.
Can some one help me out please.
Thanks for sharing from your experience.
Tom.
Correct Answer by Sushil Kumar Katre about 8 years 6 months ago
Hi Tom,
The behavior for HWIC-4ESW which you have observed is normal. This module is a layer 2 module and does not have layer 3 functionality. Just the way you can not assign IP addresses directly on a 2960 switch, you can not assign ip address directly on the physical interface of this router.
However, what you can do is, to create 4 VLANs and 4 SVIs on the router. Assign an IP address on each of these SVIs and then bind each physical interface with a particular VLAN.
Have a look at the following link - http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/esw_cfg.html#wp1051418
HTH.
-> Sushil
Correct Answer by Jon Marshall about 8 years 6 months ago
Tom
The HWIC-4ESW is the equivalent of a layer 2 switch only so you can't assign IP addresses to the physical ports. What you can do is create a L3 SVI and assign the port into that vlan ie.
create the vlan
2811# vlan database
2811(vlan)# vlan 10
2811(vlan)# exit
int vlan 10
ip address 192.168.5.1 255.255.255.0
and then assign the interface into that vlan
int fa0/0/0
switchport access vlan 10
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 12/30/2008 - 00:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tom
create the vlan
2811# vlan database
2811(vlan)# vlan 10
2811(vlan)# exit
int vlan 10
int fa0/0/0
Jon
tomocisco Tue, 12/30/2008 - 05:38
Hi Jon,
I've noted your input above.
I'll now try it out on my network. I believe it will work.
I'll get back to you.
Thanks so much.
Tom
Correct Answer
Sushil Kumar Katre Tue, 12/30/2008 - 03:04
  • Gold, 750 points or more
Hi Tom,
HTH.
-> Sushil
tomocisco Tue, 12/30/2008 - 05:35
Hi Sushil,
Thanks so much.
I looked at the link you suggested and it is very informative. I will now try out the configurations on our network.
Tom
