Stackwise - 3750s
Dec 30th, 2008
I have an existing switch stack of 3 cisco 3570s. I need to add a new switch to the stack. Is any configuration on this new switch necessary, or can i just connect it to the stack and it will pick up the config from the current established switches?
Thanks in advance!!
mike.1979 Tue, 12/30/2008 - 05:53
Great, thanks Guiseppe.. I just don't want to cause any problems with the configuration of the original switches.
So long as I change the priority on the new switch it should work? I dont need to change any other configuration on the new switch - spanning tree, vtp etc?
Thanks again!!
