error message in VSS
Dec 30th, 2008
I have 2 Catalyst 6500 working as VSS.
After making an upgrade of IOS (current: s72033-ipservicesk9_wan-mz.122-33.SXI.bin) gives the following error message:
SW1_SP: Insertion of mld_s_g_type in the tree failed WAVL grp
I searched information about this message but I have not found anything, someone who knows it?
burleyman Tue, 12/30/2008 - 05:30
If I am not mistaken this points to an internal software error. I would gather all the info and open a TAC case.
I will see if I can find some info on it.
burleyman Tue, 12/30/2008 - 05:37
You could also run show tech-support and see if anything shows up on that, you will need to run it for the TAC case anyway.
sdurn Tue, 12/30/2008 - 06:30
this error is referred only to the supervisor in sw1 and it's not the same with supervisor in sw2...
it can be due to a bad insertion of the card?
burleyman Tue, 12/30/2008 - 07:11
It could be. I did some further checking and the WAVL does point to a software issue but I could not find the exact error anywhere. It could be some type of bug. We run VSS here but we are not running that IOS we use advipservicesk9_wan-vz.122-33.SXH3.bin
I would open a TAC case if you can or maybe reload the software as maybe it got corupt.
