Problem with backup-CallManager Version 4.2.1
Dec 30th, 2008
Hi Guys,
I did the backup the Cisco CallManager and when I am trying restore in another machine is appearing the following messages:
CCM.exe - Application Error
The instruction at “0x0442e8a7” referenced memory at “0x00000000”. The memory could not be “read”'
Click on OK to terminate the program
After click ok appear another message error
CTIManager.exe - Application Error
The instruction at “0x102fe8a7” referenced memory at “0x00000000”. The memory could not be “read”'
Microsoft Visual C++ Runtime Library
Program: C:\Program Files\Cisco\bin\CallBackService.exe
This application has requested the Runtime to terminate it in na unusual way.
Please contact the application's support team for more information.
Another error
CiscoMessangingInterface.exe - Application Error
Another error
CallBackService.exe - Application Error
I need install again the OS and CCM?
Thank You,
Wilson Santana
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 12/30/2008 - 06:26
exact CUCM version as backup?
CCM services all running?
have you tried a simple reboot?
reinstalling BARS?
java
if this helps, please rate
wilsonsant Mon, 01/05/2009 - 05:34
Hi Javalenc,
I am sorry for answer only now. We did all the procedure, but, didn't solve the problem. We will go install the software again.
Thank You,
Wilson
Rob Huffman Mon, 01/05/2009 - 06:47
Hi Wilson,
Hope all is well my friend! Just to add a note to the good tips from our friend Java (+5 Java!) Here is a good doc that has all the info for doing Backups and then restoring on the new box using the .tar file;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bars/4_0_11/restore1.html
Make sure that you have everything you need on hand CCM cd's, OS with proper release,all SR's, Locale files, any custom ringlist or background files, any phone firmware files that have changed since the base install etc. etc. These things should all be kept from build to build just in case.
Hope this helps!
Rob
