Inter-group call on Callmanager 4.0
Dec 30th, 2008
I have callmanager 4.0 installed, i want to achieve a scenario where three different groups could only call within the group but not inter-group. I set up 3 different callingsearchspace/partition but still the group can do intra group call, which i do not want. {Group A = 100X, Group B =200X, Group C = 300X}
Chris Deren Tue, 12/30/2008 - 08:05
You are on the right path, all of these is accomplished via CSS/PT, so here is what you need to do:
put all group A DNs in parition lets call it GroupA_PT,
put all group B DNs in GroupB_PT
put all group C DNs in GroupC_PT,
create 3 Calling Search Spaces, each referencing it's own PT, and not the others, i.e.
GroupA_CSS, inlcudes GroupA_PT
Assign corresponding CSS to local devices, i.e. phone in group A would use GroupA_CSS.
That's it!!!
HTH,
Chris
exchange1 Tue, 12/30/2008 - 11:05
Thank you Chris, I actually did what you suggested but I can still make inter group calls. Is there any other things I need to do?
exchange1 Tue, 12/30/2008 - 11:37
Hi Chris,
It is working now, I restarted the server and it is fine.
