Exporting CiscoWorks Device database to 3rd party apps
Dec 30th, 2008
All, has anyone exported the CiscoWorks LMS 3.01 device management or RME database files to a 3rd party application, if so what is the best way to allow access to this file
Joe Clarke Tue, 12/30/2008 - 09:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Exporting can be done in a few ways. Probably the easiest way is to use dcrcli from the command line. This way, you can automate the export (and possibly the import). For example, to export the device and credential list to CSV using dcrcli:
dcrcli -u admin cmd=exp fn=dcr.csv ft=csv
