no enable password
Dec 30th, 2008
I am applying certain security policies from given template such as
1. enable secret <password>
2. no enable password
Due to #2, I couldn't telnet into the device anymore. Is anything additional required.
Jon Marshall Tue, 12/30/2008 - 10:47
Where does it fail when you try to telnet. You should be fine without the enable password but you still the password configured on the vty's.
Jon
cisco_lite Tue, 12/30/2008 - 11:08
I would like to correct my first post.
I can telnet into the device (Cat6500), but when I do 'enable' it says 'No password set'.
I believe the vty password is intact thats why I can successfully telnet into the device.
Can 'no enable password' remove the 'enable secret ' by any chance.
viyuan700 Tue, 12/30/2008 - 16:59
yes u need a enable passowrd.
Edison Ortiz Tue, 12/30/2008 - 17:11
Really?
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#enable password cisco
R1(config)#do show run | i enable
R1(config)#enable secret cisco123
R1(config)#no enable password
enable secret 5 $1$0Obq$Juq8Mz8QtkNdy0Y/V5x5Z1
R1(config)#exit
R1 con0 is now available
Press RETURN to get started.
R1>en
Password:
R1#sh run | i enable
R1#
__
Edison.
Richard Burts Tue, 12/30/2008 - 20:05
I believe that Vishwamurti must have understood the original question much differently than Edison and I did.
Edison is quite right: the operation of enable password and of enable secret are entirely independent. Removing enable password will NOT remove enable secret. If the 6500 is giving an error about no enable password then the enable password was removed and there is no enable secret. Either the enable secret was overlooked in the original configuration or there was a keystoke error that produced a syntax error in the attempt to configure enable secret. But the generation of that error message indicates that neither the enable password nor the enable secret are configured.
Rick
finotti_br Mon, 12/19/2016 - 04:39
The answer is that when you disable "enable password" after configure an "enable secret" you will just get access in line vty with SSH transport to achieve EXEC mode using enable secret. No telnet is permitted anymore after thus configuration. I think this kind of thing is to secure more strongly because "enable password" has a weak encryption.
