SIP 400 Bad Request - 'Malformed/Missing FROM: field'
Answered Question
Dec 30th, 2008
Running CME on a UC520, uc500-advipservicesk9-mz.124-22.T.bin
Seeing the following on incoming calls:
Dec 30 18:35:36.544: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Malformed/Missing FROM: field'
Reason: Q.850;cause=100
Date: Tue, 30 Dec 2008 18:35:36 GMT
From: "SAMAROO,GANESH" <sip:[email protected]>;tag=VPSF506071629460
Allow-Events: telephone-event
Content-Length: 0
To: <sip:[email protected]:5060>;tag=AF4302E4-2030
Call-ID: [email protected]
Via: SIP/2.0/UDP 216.82.224.202;branch=z9hG4bKe7fb.3e3b87c6.0,SIP/2.0/UDP 4.79.212.229;branch=z9hG4bKe7fb.4dde2fc3.0,SIP/2.0/UDP 4.68.250.148:5060;branch=z9hG4bK506071629460-1207340264767
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
The SIP provider said they saw a similar error with the Call Manager where the "," in the from filed was not being recognized. Does anyone know if the error has carried over to the CME code?
Is there a way to force a value in the "from" field for incoming SIP calls? Calls are failing due to this.
Thanks.
Correct Answer by Nicholas Matthews about 8 years 3 months ago
Yes, this is a known bug with the comma in the calling name. I don't have the bug ID on me at the moment, but this has been raised and some searching on the bug toolkit should bring something up. I can give you this bug ID later. I would look for this to be fixed into 12.4(20)T2 and / or 12.4(22)T1.
hth,
nick
Overall Rating: 5 (1 ratings)
Correct Answer
Nicholas Matthews Tue, 12/30/2008 - 13:40
  • Red, 2250 points or more
hth,
nick
m-ketchum Tue, 12/30/2008 - 13:44
Thanks Nick.
Are earlier verions of IOS, such as XW9 affected?
Thanks again.
