Destination NAT - IOS router - traffic inside
Dec 30th, 2008
I'm having an issue using a destination nat. I'm not sure if this is the best way to do it.
I have a static nat in place mapping a public ip 10.10.10.1 to internal ip 192.1.1.1. All is working well.
Howerver I need the public ip 10.10.10.1 to be accessible to all clients on the internal network. (DB programers hard corded IPs into there program).
Currently I can't ping the public address of the static nat internally.
What type of nat / acl do i need to put in place to get this to work?
Any documentation or advice would be helpful.
John Blakley Wed, 12/31/2008 - 11:32
You may be able to use policy based routing. Create an access-list permitting all of your internal subnet to the one internal host, but do it by public IP.
ip access-list ext TRANSLATE
permit ip 192.168.1.0 0.0.0.255 host
Then create your route map that forces all of those hosts going to that destination to the internal address instead.
(From memory )
route-map INTERNAL permit 5
match ip address TRANSLATE
set ip next-hop 192.168.1.1 <--your internal server ip.
Again, I don't know if this will work, but it might.
HTH,
John
