Error when doing a write mem on 3525 router
Dec 30th, 2008
When I change the config on our 3525 router and then do a write mem command I get the following.
[OK]private-config file open failed (File table overflow)
Any one seen this?
Overall Rating: 5 (1 ratings)
Pari Thiagasundaram Tue, 12/30/2008 - 12:52
I have no clue what version you are running. Most probably you might be hitting CSCds44607. [not enough details on your 3525].
Workaround would be save your config to a file and reload the box and then load it from the file.
burleyman Tue, 12/30/2008 - 12:56
Sorry...I had the info just forgot to put it in the question...just grabbed it again.
3825#show ver
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(20)T1, RELEASE SOFTWARE (fc3)
Technical Support:
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 24-Sep-08 18:40 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
PRS_3825 uptime is 9 weeks, 42 minutes
System restarted at 22:11:16 CET Tue Oct 28 2008
System image file is "flash:c3825-advipservicesk9-mz.124-20.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3825 (revision 1.2) with 487423K/36864K bytes of memory.
Processor board ID FCZ123772WN
2 Gigabit Ethernet interfaces
35 Serial interfaces
3 Channelized/Clear E1/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
burleyman Tue, 12/30/2008 - 13:24
Thanks. I will do that. Do you know if I am at major risk. I checked the bug and it does not really say.
arunkv1980 Thu, 06/12/2014 - 02:45
I have the same error in Cisco 3845
in0211-ertr-03#wr mem
in0211-ertr-03#show ver
Cisco IOS Software, 3800 Software (C3845-IPBASEK9-M), Version 12.4(22)T2, RELEASE SOFTWARE (fc4)
Technical Support:
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 19-Jun-09 19:42 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Richard Burts Thu, 06/12/2014 - 14:46
Probably the best answer is the one from 5 years ago - copy your running config to a file, reboot the router, load the config from the file back to the router.
Obviously we do not know for sure what caused this problem. And there is no guarantee that it will not happen again. But this is the recovery from the current problem. If the problem is hardware related then there is not much you can do other than replace the router. If the problem is software related a change in software version might help (but on a box this old that is also problematic).
arunkv1980 Wed, 07/09/2014 - 23:51
in0211-ertr-03#show run | in boot
boot system flash c3845-ipbasek9-mz.124-22.T2.bin
boot system flash
boot system flash c3845-advipservicesk9-mz.151-4.M8.bin
Richard Burts Thu, 07/10/2014 - 10:47
Based on this output it looks like your router is actually running 12.4(22)T2 but that you would want it to run 15.1(4)M8. Is that correct? If so then changing the order of the boot system commands would get you the results that you want.
