Wireshark packet capture
Dec 30th, 2008
Can I configure Wireshark to capture ip header only, not the whole packet. Also, can I sample the capture in such way that only 1 out 10 packets will be captured. We are trying to use Wireshark to do the same job as netflow.
crow930us Tue, 12/30/2008 - 17:09
  • Bronze, 100 points or more
You can use expressions to filter what you receive or what you view. You can also filter a capture based on the conversation that is happening. A better place for more info would be the wireshark page: http://www.wireshark.org/ or Laura Chappell's page at http://www.wiresharktraining.com/ Wireshark does have many options to filter a capture.
