Attendant Console
Dec 30th, 2008
I have an attendant console thats line status is displaying ?'s for all lines. I have rebooted the attendant console server service and nothing. The CM version is 5.1 any ideas?
gogasca Wed, 12/31/2008 - 13:15
  • Green, 3000 points or more
Which exact version for CUCM?
Does the AC PC has a Firewall enabled?
Other PCs works?
CUCM has "Application Dial Rules" under call routing which is mainly used for CUPC dialing. This allows a user to dial phone numbers that come from LDAP as 10 digit numbers, to append a 91 to everything so that call manager can route the call.
Application Dial Rules are applied to all CTI applications, so AC is also affected.
On the AC client go to: C:\Program Files\Cisco\Unified CallManager Attendant Console\data\GlobalSetting.xml
Change: false<\DialRuleForDialingOnly> to true<\DialRuleForDialingOnly>
Save the file, log out of AC and then log back in.
You can also enable AC tracing and let us know
jjohnson1980 Mon, 01/05/2009 - 11:18
I should have been more specific, the line status for the Directory numbers display as ?. Not the line status of the AC itself. Ill get back with the exact version of the CUCM a little later.
jjoseph01 Wed, 01/07/2009 - 08:05
I had this issue also a little while back. There were a couple of things I remember I had to do.
1. Update the java to the latest version.
2. Restart a service in particular in Servicability. I cant remember exactly what that service was right off, but it has happened several times before, and I had to restart that service each time.
This was in 6.1 though
jjohnson1980 Wed, 01/07/2009 - 09:16
I'm updating Java on the PC containing the AC correct?
Ive restarted the AC server in serviceability already with no luck.
CHRIS CHARLEBOIS Wed, 01/07/2009 - 12:09
  • Silver, 250 points or more
In my experience, that is caused by a firewall; either a firewall or ACL on the network between the client PC and the Server running AC or (and I've run into this more often) a Windows firewall on the PC. Some organizations use Windows Group Policies to enforce personal firewalls on Windows and that prevents the UDP traffic through.
jjohnson1980 Wed, 01/07/2009 - 12:15
Would that cause intermittent problems? I learned today that is whats is actually happening.
CHRIS CHARLEBOIS Wed, 01/07/2009 - 12:19
If it's a group policy issue, it could depend on who is logged into the operating system at the time. Could that be the 'intermittent' factor?
richaminzia Mon, 02/02/2009 - 13:36
If you are still having this issue, check to see if there are any firewall settings in the pc where the AC Console application is installed. You must disable any Windows Firewall settings.
jjohnson1980 Mon, 02/02/2009 - 14:38
I checked that and the java version. I am about to check what CM it is registered to compared to what CM the phone are registered to. THey should be registered to the same CM. If that doesnt help then ill check the LMHOST and HOST files and add the IP addy and hostnames to see if that works.
