LMS 2.6 Pulling Router Config
Dec 30th, 2008
In LMS 2.6 how can I pull the config from a Cisco Router? I know only the Read SNMP String. Thanks for any help!
Joe Clarke Tue, 12/30/2008 - 18:02
If all you have is the SNMP read-only community string, you cannot get the configuration. You must have one of either the SNMP read-write community string, or the ability to login via telnet or SSH, and get enabled.
If you configure those credentials under Common Services > Device and Credentials > Device Management, then RME will be able to download and archive the configuration from the router.
