ccsp title
Dec 30th, 2008
Hi ,
I have completed CCNA, SND , SNRS (642-503) , i have a question if i do it as below will i be able to get the ccsp title
CCNA finish
SND finish
SNRS (642-503) finish
if i pass SNPA 642-523 before it expires
SNAF need to pass
SNAA need to pass
here i will have 4 required 1 elective please confirm
Thanks .
paul_alexander Wed, 12/31/2008 - 04:34
You have a choice of doing SNPA or SNAF, not both. You would still need to complete the IPS exam and the elective to certify.
205214117 Wed, 12/31/2008 - 06:58
Hi ,
Thanks for you reply what confused me is in CCSP certfication page it show under required exams following
SNRS 642-503 or 642-504
so four from above example for SNRS 642-503 or 642-504 meaning one of two not both but it didnt say SNPA or SNAF , snpa and snaf show in two sepearte rows
can you please comment on this.
paul_alexander Wed, 12/31/2008 - 07:30
I see what you mean, it is a tad confusing. But considering the SNAF exam replaces the SNPA (by phasing out the PIX) id say they wont count it towards your 'required' exams.
205214117 Wed, 12/31/2008 - 08:34
Thanks for your prompt reply,
sorry to ask again I just need to confirm it, weather this combination is possible .a confirmed answer ,, since i am planing to do SNPA because pix is widely deployed and used in many companies so its very importent that we have a very good knowledge about pix also so i was thinking of above combination .
paul_alexander Wed, 12/31/2008 - 09:10
I cant tell you for sure. I'd speak to cert support, or maybe someone else can comment.
But I'm 99% sure the answer is going to be that you need to do SNPA OR SNAF. Doing both will not count as two modules.
205214117 Wed, 12/31/2008 - 19:30
Thanks Paul,
Your prompt reply is much appreciated any way can you please check with cert support and update.
205214117 Thu, 01/01/2009 - 19:49
Hi Paul,
You or Anybody knows any email address of cisco certication support so i can drop a email,
Thanks in advance
