Routing over 19.2Kbps link
Dec 30th, 2008
please advice I am working on a project where max bandwidth of each link is 19.2kbps.
There are total 70 sites interconnect via the 19.2kbps links.
Attach is the sample diagram represent a network segment, this is how all 70 sites connect to main site
Please advice will OSPF/EIGRP works as there will be a lot of congestion.
Data requirement of application is 4.8kbps only for each site.
What do you suggest if upgrade of bandwidth is not possible then will the network work (seems not to me)
Atif
Rupesh Kashyap Tue, 12/30/2008 - 21:41
You have two solutions as you told that Data require only 4.8 kbs out of 19.2 kbs.
1. Implement QOS. Reserve bandwidth with LLQ or Police.
2. Use Static route only
