DHCP through PIX firewall
Dec 30th, 2008
I have a Site A and Site B at different geographical location,which are connected using Routers through leased line.
Now at both the location behind the router I have connected a Cisco PIX 515E firewall,behind the firewall I haveconnected L2 switch in both locations.At Site A all clients are connected to L2 switches,and a DHCP server isassigning a dynamic IP address for all clients,at Site B there are no clients but servers and a DHCP server are connected.
Now at Site A,if the DHCP server is down,how the clients will get the dynamic IP address from teh DHCP server which is at Site B.
Is it possible in this scenario?
Please help me I am in the process of desiging the DR site .
Thanks and Regards,
LAVANHOLY
Pravin Phadte Wed, 12/31/2008 - 02:51
  • Silver, 250 points or more
Are u running a Tunnel IPsec from both of this pix box ?
If you have then you can configure the pix as dhcp server
!--- Specifies a DHCP address pool and the interface for the client to connect.
dhcpd address 192.168.1.5-192.168.1.7 outside
!--- Specifies the IP address(es) of the DNS and WINS server
!--- that the client uses.
dhcpd dns 192.168.0.1
dhcpd wins 172.0.0.1
!--- Specifies the lease length to be granted to the client.
!--- This lease equals the amount of time (in seconds) the client
!--- can use its allocated IP address before the lease expires.
!--- Enter a value between 0 to 1,048,575. The default value is 3600 seconds.
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd auto_config outside
!--- Enables the DHCP daemon within the Security Appliance to listen for
!--- DHCP client requests on the enabled interface.
dhcpd enable outside or inside
dhcprelay timeout 60
Check the link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806c1cd5.shtml#server
