Wlan solution
Dec 30th, 2008
Hi everyone and I wish every one Happy new year
So I have got one problem about Wlan
so I configured wlan with 801.x security how ever it doesn;t work normally in roam enviroment is there any solution for this I mean is the cisco has the solution about this feature I don;t want use wep or wpsk I want use certificate with 801x so authenmtication via radius to Active directory so plzzz let me know if there any solution abt this one thanks
aga_huseynov Fri, 01/02/2009 - 05:07
thanks for u quick response but if I have no cisco AP so can I use it with other Ap for example 3com and linksys will it work
Istvan_Rabai Mon, 01/05/2009 - 10:42
Hi Agha,
I don't have experience with these compatibility issues.
You probably should look for the answer on forums specific to these vendors.
