Pravin Phadte Wed, 12/31/2008 - 02:41
  • Silver, 250 points or more
what kind of wan ports are u looking for ?
sachinraja Fri, 01/02/2009 - 11:54
  • Red, 2250 points or more
Hello Kumar
Firewalls are normally chosen, taking into consideration a lot of important points:
1) no of interfaces needed (Inside, outside, DMZ)
2)Throughput of FW
3) max connections
4) Feature sets needed (IPS etc)
5) Max vpn support..
and many other points.. ALso based on the end user business or use (Datacenter, remote office etc)
Attaching a URL which has comparisons of all the ASA firewalls. Check what you need. You can look out for 5510,20 or 40 kind of appliance.
http://cisco.com/en/US/products/ps6120/prod_models_comparison.html
Hope this helps.. all the best.. happy new year.. rate replies if found useful..
Raj
Pravin Phadte Sun, 01/04/2009 - 22:39
Thats good information provided by sachinraja.
Most of the firewalls in market are without WAN ports. All eth,FA,Gbic ports in cisco.
http://www.nokiaforbusiness.com/nfb/find_a_product/product_details.html?guid=0e035565eec86110VgnVCM200000718ef393RCRD&cat=e01e5565eec86110VgnVCM200000718ef393RCRD
check link above for more inforation on NOkia
