NAC Guest Server with WLC
Answered Question
Dec 31st, 2008
  • Bronze, 100 points or more
Dear All,
I just need to confirm that is it possible that we add same WLC to CAS(wireless users) and NAC Guest Server(wireless guest users) or I must need one more WLC for NAC guest server.
Correct Answer by sachinraja about 8 years 2 months ago
Hello Nomair
You do not need seperate WLC's.. NAC guest servers are just normal radius servers, used for authentication. You can integrate your existing WLC's, which are added on IB or OOB to your CAS, with the guest server. I'm attaching a doc which gives info on how to setup wlc's and guest servers.
Hope this helps.. all the best.. happy new year to you. rate replies if found useful..
Raj
Overall Rating: 5 (3 ratings)
Correct Answer
sachinraja Fri, 01/02/2009 - 11:49
  • Red, 2250 points or more
Hello Nomair
Raj
