Site-to-site VPN question
Dec 31st, 2008
Here is the question, is there any way to make vpn. Think that one router has subnet A in his inside. The other asa firewall has B and C networks. What I want is B and C can reach A via VPN. But the A should only reach B, it shouldnt reach C network. How can we implement this? Is this possible because I know that vpn ACL's should be symmetric.
Jouni Forss Wed, 12/31/2008 - 01:45
Not really expirienced with the VPN, but couldnt you just build the L2L VPN with symmetric ACL on both sides and use different ACL to limit the traffic from the local networks as you discribed?
For example have the actual L2L VPN ACLs as:
A --> BC
permit ip a.a.a.a mask b.b.b.b mask
permit ip a.a.a.a mask c.c.c.c mask
BC --> A
permit ip b.b.b.b mask a.a.a.a mask
permit ip c.c.c.c mask a.a.a.a mask
Then use ACL on the B and C LANs interface to allow traffic freely to a.a.a.a from b.b.b.b and c.c.c.c
And would the router perhaps need abit different ACLs as it doesnt handle the traffic the sameway as the ASA on the other end?
Something like
permit ip a.a.a.a. mask b.b.b.b mask
permit tcp a.a.a.a mask c.c.c.c mask established
deny ip a.a.a.a mask c.c.c.c mask
or something to that direction?
As i said I aint too expirienced with VPNs and i have never really built them with anything else other than 2 firewalls as endpoints.
