What is "ip subnet-zero"
Dec 31st, 2008
I seem to be stuggling with the ip subnet-zero. It came up in an exam when it said pc1 needs to contact pc2 (with a few routers in between) and asked how many zero subnets did it pass through to get to pc2, I got it wrong and a few more questions came up about it. It's hardly mentioned in my Cisco ICND1 and 2 book.
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Wed, 12/31/2008 - 01:59
  • Hall of Fame,
    Founding Member
Hello Andy,
when IP subnetting was introduced at first the first block was reserved to avoid confusion with the network subnet.
Example:
192.168.5.0/24 Class C major network
If we divide it in /28 subnets
192.168.5.0/28
192.168.5.16/28
192.168.5.32/28
the ip subnet-zero that is now a default allows to use the first
192.168.5.0/28
the old rule for the subnets you can get was
if K=Subnet.len - network.len
2^K -2
so in our example would be 2^4-2 14
now you can use also the first subnet and the last one.
Because modern routing protocols are classless they carry the mask of updates they can handle 192.168.5.0/24 and 192.168.5.0/28 without problems
Hope to help
Giuseppe
elkono200 Wed, 12/31/2008 - 02:01
hi,
ip subnet-zero (default active on new ciscos) is a command that you allow to use the first and last subnet on a subnetted Class C network.
ie.
Class C subnetted - 4 networks
192.168.10.0-63
192.168.10.64-127
192.168.10.128-191
192.168.10.192-255
without "ip subnet-zero" you shouldnt use the 1st and last subnetted network, because it could be a whole Class C network so the 192.168.10.0 is the network and 192.168.10.255 is the broadcast from it.
hope that helps.
elkono
