Access-list problem
Dec 31st, 2008
hi friends ,
I wrote an access-list that permit only 2 hosts from the specified network. and apply this list to interface inbound . the first host are accessible but the second not.
Who can help me ?
the list definition :
ip access-list extended site2internal
permit tcp 172.25.0.0 0.0.255.255 host 172.20.1.2 eq www
permit ip 172.25.0.0 0.0.255.255 host 172.20.0.20
deny ip any 172.20.0.0 0.0.255.255
permit ip any any
172.20.1.2 accessible
172.20.0.20 not-accessible
Giuseppe Larosa Wed, 12/31/2008 - 02:03
  • Hall of Fame,
    Founding Member
Hello Reza,
are the two hosts
in the same ip subnet ?
you need to verify also routing in the return path
Hope to help
Giuseppe
Reza Rezazadeh Wed, 12/31/2008 - 02:43
Hi Giuseppe ,
Yes to hosts are in a same subnet , 255.255.0.0.
the routing are correct.
ip route 172.20.0.0 255.255.0.0 GigabitEthernet0/1.1
This hosts are accessible from other subnets, that no access-list are applied.
Best Regards
Reza Rezazadeh Fri, 01/02/2009 - 23:08
Hi everyone,
My problem exist , I try to develop the access-list but only one host are accessible :
permit tcp 172.25.0.0 0.0.255.255 host 172.20.0.23 eq ftp
permit tcp 172.25.0.0 0.0.255.255 host 172.20.0.6 eq domain
permit ip any any
With this configuration I intend from subnet 172.25.0.0 to 172.20.0.0 only hosts : 172.20.0.20 , 172.20.0.23 , 172.20.0.20 , 172.20.0.6 , 172.20.1.2 with appropriate port number are accessible.
But only host 172.20.1.2 are accessible and other not.
How can help me to solve this ?
Best Regards
Reza Rezazadeh Sat, 01/03/2009 - 00:05
I thought that the problem is with 172.20.0.x hosts, hosts that the third octet is "zero" . how can I correct this ?
glen.grant Sat, 01/03/2009 - 03:31
  • Purple, 4500 points or more
Shouldn't matter if its a zero subnet. I would verify the layer 3 subnet definition is 255.255.0.0 . If yes also verify on the clients that the mask is is the same 255.255.0.0 . If the acl is in the exact order you posted I don't see anything to keep it from working.
