DFM custom rules - syntax problem
acarnegie
I am trying to create a custom rule that will allow me to increase the %Utilisation threshold on specific trunk ports on a number of switches. I cannot get the syntax of the rule to be accepted can anyone help me with this? The rule I am using is copied below.
Thanks.
(TrunkPort.SystemName equals "*****-3750-01.bgs.com" AND
TrunkPort.Description equals "GigabitEthernet1/0/49" OR
TrunkPort.Description equals "GigabitEthernet2/0/49") OR
(TrunkPort.SystemName equals "#####-3750-01.bgs.com" AND
13 Replies 13
Joe Clarke
Complex rules like this are not supported. You will not be able to mix AND and OR like this with DFM customizable groups as you cannot create child groups. You would need to modify separate groups for this.
Should the following syntax work?
If so I can create a custom group for each device I am interested in changing the threshholds on.
This won't work as expected as you'll get interface GigabitEthernet1/0/49 from the device with name *****-3750-01.bgs.com, as well as all interfaces Gigabit2/0/49.
Is is possible to create a a single rule that will monitor both ports 49 & 50 on a specific device? Or will I have to use multiple custom groups, If this is the case I don't believe there will be enough groups for the number of interfaces I wish to change the threshold on.
What version of DFM do you have? If 3.0 or higher, complex rules should now work, but there's a catch. You have to have a space between your parentheses and the rule text. For example:
( TrunkPort.Description equals "GigabitEthernet1/0/49" OR
TrunkPort.Description equals "GigabitEthernet2/0/49" )
Thanks for your help but I still can't get this to work. I am using DFM 3.0.4
When I use your suggested syntax the only member in the group is port 1/0/49 and not both ports 1/0/49 & 2/0/49.
Do you have any suggestions?
It works locally for me. Make sure you resave your priority settings, then reapply changes after making any changes to the group ruleset.
Hi, I have tried applying this again, and still only get port 1/0/49 assigned to the group. Are there any trace logs I can view to try and solve this?
I wonder if port 2/0/49 is not classified as a trunk port. Find out the group to which this port currently belongs. You can do this by looking under the system-defined groups under Manage Thresholds.
Thanks again for your continued help with this. I have checked you suggestion and neither ports 1/0/49 or port 2/0/49 are showing as trunk ports. In actual fact port 1/0/49 is showing as an access port and 2/0/49 is not showing in any of the system groups. I have checked the device details in DFM and both ports managed state is set to true.
The switch ports are configured as trunks, I have copied their config below. Do you have any suggestion as to why they would not be showing as trunk ports in DFM?
description #####
switchport trunk native vlan 301
switchport trunk allowed vlan 301,600-613
switchport mode trunk
switchport nonegotiate
no snmp trap link-status
spanning-tree portfast
interface GigabitEthernet2/0/49
description *****
switchport trunk native vlan 100
switchport trunk allowed vlan 100,600-613
DFM classifies ports as trunk ports if they are connected to another device which DFM is managing. Else, they are classified as access ports.
We are using LMS 2.6 and DFM 2.0.8.
I wish to create a DFM group in order to isolate 4 interfaces. It's 4 trunk that i wishto monitor with a utilization percentage of 70%. But keeping all other trunk at 40%.
Is it possible and how ?
Please start a new thread for your issue.
