7975 Device Default missing
Dec 31st, 2008
Call Manager 4.2.3 SR2 has the 7975 firmware and can auto-register a 7975 with the Standard 7975 Phone Template, however that template is not displayed in Phone Template options nor is there a device default listed for the 7975.
Rob Huffman Wed, 12/31/2008 - 06:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Edil,
Support for the 7975G was not added until the release of CCM 4.2(3)sr2b as shown below. So, you would need to upgrade to at least that version. There are many bug fixes for 4.2(3) in these newer versions as well;
7975G Call Control compatibility
Supported in Cisco Unified Communications Manager Versions 4.1(3)sr5b, 4.2(3)sr2b, 4.3(1), 5.1.1(b), 5.1(2), 6.0(1) and greater
Supported in Cisco Unified Communications Express and SRST Version 4.1
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8538/product_data_sheet0900aecd8069bdb7.html
Here is the path in the Voice Software downloads to the newer 4.2(3) SR's
Voice and Unified Communications > Cisco Unified CallManager Version 4.2 > Unified Communications Manager Updates > 4.2(3)
Hope this helps!
Rob
