MCU Upgrade
Dec 31st, 2008
I have an MCU with version 5.5, the MCU needs to integrate with OCS 2007, for use as a video for this I need to upgrade a version 5.6
how to is procedure to upgrade?
In the CD of the MCU is not the UpgradeUtility.exe
have already downloaded these files from cisco.com
CUVCM-MCU_5_6_1_1_13_CS
CUVCM-MVP_5_6_1_0_4_CS
But I do not want to apply them as I needed to have risen EMP backwards first and then do not like the procedure.
mparzynski Thu, 01/29/2009 - 12:08
The documentation isn't the greatest.
The two files you would have downloaded are zip files. From them you will extract executable (.exe) files with essentially the same names. Just run those two files, they have the upgrade utility and the new code in a single package, you don't need anything more.
Mike
