Two routing protocols using same rtr ID cause duplicate rtr id in EIGRP?
Dec 31st, 2008
  • Gold, 750 points or more
Hi all,
I have observed logging of "Ignored route, dup router: 10.40.160.1"
in the EIGRP events in one of our L3 core switch. Both the OSPF & EIGRP seems to be using same router id:
4510-S1#sh ip eigrp topology
IP-EIGRP Topology Table for AS(29)/ID(10.40.160.1)
4510-S1#sh ip ospf data
OSPF Router with ID (10.40.160.1) (Process ID 100)
I know this (10.40.160.1) not being used anywhere in our network. OSPF being redistributed into EIGRP.
4510-S1#sh ip eigrp events
15 10:41:38.933 Poison squashed: 10.199.21.0/24 rt gone
16 10:41:38.933 RDB delete: 10.199.21.0/24 10.40.1.1
17 10:41:38.933 RDB delete: 10.199.21.0/24 10.40.2.1
18 10:41:38.933 RDB delete: 10.199.21.0/24 10.40.25.3
19 10:41:38.933 RDB delete: 10.199.21.0/24 10.40.11.1
26 10:41:38.933 Ignored route, neighbor info: 10.40.25.3 Vlan26
27 10:41:38.933 Ignored route, dup router: 10.40.160.1
No production issues anyway. But what causing the dup rtr id entries..?
Also what is the exxact meaning of:
Thank you in advance
MS
Giuseppe Larosa Wed, 12/31/2008 - 09:18
  • Hall of Fame,
    Founding Member
Hello Mehboob,
I would investigate on neighbor 10.40.25.3 on Vlan26.
the EIGRP router-id is exported only on external routes data structures where there is a field where it is placed.
So the effect should be on a route imported in EIGRP on the neighbor 10.40.25.3
Hope to help
Giuseppe
