Active LED not glowing in Sup V 10GE
Dec 31st, 2008
Dear friends,
I am unable to use the second Ten Gig port on th Supervisor V-10GE
. The chassis is 4507 chassis and the IOS version is 12.2(25)EWA6.
The supervisor module is WS-X4516-10GE.
The first Ten Gig port is already in use but the second Ten Gig port has the "Link" and the "active" led turned off. I thought that the Active LED should glow always irrespective of the port status. Has anyone come across this before? Please advise.
Thanks a lot
Gautam
Giuseppe Larosa Thu, 01/01/2009 - 01:17
  • Hall of Fame,
    Founding Member
Hello Gautam,
Happy new year
according to the configuration guide of your release
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25ewa/configuration/guide/sw_int.html
all ports are enabled by default.
From CLI does the switch sense the optical transceiver presence or not ?
We have in one campus the same devices I will give a look.
In our experience we had already to change several 10GE transceivers so there is a chance that your port has a transceiver that is not working anymore.
Hope to help
Giuseppe
gautamzone Thu, 01/01/2009 - 01:33
Thanks Giuseppe and Wish you a very Happy new Year too.. Yes, the transceiver is detected (as per sh int status output). I doubt if the slot is an issue here because i ave tried different LX4 transceivers too.
Note: The Active LED on the slot does not glow at all. I believe that the Active LED should glow whether or not the Link is down?
Giuseppe Larosa Thu, 01/01/2009 - 05:54
  • Hall of Fame,
    Founding Member
Hello Gautam,
from ciscoview I see the link up but the active is not lighted but I don't know if it reflects the real LEDs (all of them)
I have C4506 with WS-X4013+10GE and IOS cat4500-ipbasek9-mz.122-31.SGA.bin and they use the two 10GE uplinks
nothing special in the configuration
Hope to help
Giuseppe
