Busted mode switch on Catalyst 3500
Dec 31st, 2008
I've got a Catalyst 3500 XL Series switch and I need to get into it to reset the password. The mode button is broken. Is there a command I can send through hyperterminal to achieve the same effect and reach the switch: prompt?
owillins Tue, 01/06/2009 - 08:36
  • Silver, 250 points or more
You have to replace the Mode switch. Then only you can able to reset the password.
