Can you stream MoH from CM out an FXS port?
Dec 31st, 2008
I want to use an FXS port at a remote site to provide MoH to a avaya pbx at a remote site. I already have the FXS station there, but how do I configure it to constantly stream the MoH when it goes offhook?
gchaotre Thu, 01/01/2009 - 09:15
It depends on what you have.
Do you have a CUCM environment or a CUCME?
Are aiming to have the FXS as a live feed MoH source?
scott.hammond Fri, 01/02/2009 - 03:56
Callmanager, no express
yes I want to use it as a source for an avaya I have in the field. That way I can update the file on callmanager centrally...
gchaotre Fri, 01/02/2009 - 14:41
I checked and could not get this to work.
The FXS would only get MoH stream if it initiates/receives a call and is put on hold by a phone or by the CCM system.
One will not get MoH stream unless, a call is placed from the AVAYA to the FXS and then is put on hold by the CUCM cluster.
Unfortunately, I have to say that is not currently doable. A PERs could be submitted with the CSAM.
