ip domain name
Answered Question
Dec 31st, 2008
What is the reason for ip domain name in the router, even though active directory service provides DNS for the network?
Correct Answer by steve_steele about 8 years 6 months ago
"ip domain name" specifies the domain name of the cisco device itself. One of the things this is used for is security certificate generation for IPSEC, SSH or HTTPS access. The certificate will be generated using the entries you put in for hostname and domain name.
ip name-server specifies the dns servers used for resolving dns names to ip addresses.
Steve
Overall Rating: 5 (2 ratings)
Jon Marshall Wed, 12/31/2008 - 14:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The ip domain-name is used on a router so you the router can do DNS lookups. So if you type ping "server.net.com" on your router and the router has been configured with a DNS server to use it can resolve "server.net.com" to an IP address.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800c525f.shtml
Jon
Correct Answer
steve_steele Thu, 01/01/2009 - 15:30
  • Bronze, 100 points or more
Steve
