Cisco 2620xm router and Multiple (DynDNS.com) host records....
Dec 31st, 2008
I have a Cisco 2620xm router connected to DSL Modem (waiting for WIC-1ADSL card)......configured for DynDNS.
DynDNS is configured with the following:
mydomainname.net
exchsvr.mydomainname.net
ftp.mydomainname.net
ftp1.mydomainname.net
ns1.mydomainname.net
stinger.mydomainname.net
ts1.mydomainname.net
www1.mydomainname.net
My Cisco config file is:
ip ddns update method sdm_ddns2
HTTP
add »[email protected]/···e=&myip=
remove »[email protected]/···e=&myip=
interval maximum 28 0 0 0
interval minimum 28 0 0 0
interface Dialer1
description $FW_OUTSIDE$
ip ddns update sdm_ddns2 host members.dyndns.org
ip ddns update hostname exchsvr.mydomainname.net
A SINGLE Host record IP address WILL update just fine at DynDNS......If I enter any other SINGLE host the IP address WILL update just fine at DynDNS....
- So what command(s) do I need to enter, for MULTIPLE hosts so they will all update their IP address at DynDNS?
- Are my update intervals normal?
Thanks............
jbayuka Tue, 01/06/2009 - 07:07
Set your router to update a single record, and then use CNAME records to point all of your other hostnames at that record.
Update intervals depends on your dynamic DNS provider.
