CDR call report generated up to specific date
Dec 31st, 2008
When i am trying generate any calls related report through cdr its giving me error data is available up to so and so date.
Pl find attached snap shot of the same.
Pl help.
Nishit
irisrios Tue, 01/06/2009 - 08:38
  • Silver, 250 points or more
Check that the Publisher CM server has the following services running: "Cisco CDR Insert" and "Cisco CDR Analysis and Reporting Scheduler". If any of those services is stopped, please start them as they are required for CDR functionality.
Do you know what changes occurred on on your network? Were any upgrades done to CM servers? Any other changes to the CM servers?
Are there any errors in the System and/or Application logs on the CM Publisher?
When you log into CAR, are you able to search CDR records after ?
If so, the records are in the CDR database, but for some reason are not being loaded into the ART database.
