Firewall ISP Support
Dec 31st, 2008
I have a ASA 5540,and i have one ISP connect to it with outside interface and now i want to connect a 2 mbps another isp line to them is it poosible to connect with the use of extended 4ge ssm card.can a firewall support to ISP at a time.
Overall Rating: 4 (2 ratings)
chetansharma Thu, 01/01/2009 - 21:01
But i wan to know that can a firewall support two ISP at a time.means if i will use 4ge ssm(with 4 extra ethernet ports) card in Asa 5540 can i connect two different ISP to the firewall.i thnk it is not becoz at a time how two different traffic can process.
chetansharma Fri, 01/02/2009 - 03:58
means i can connect two different isp(1mbps and 2 mbps) link on a firewall(ASA 5540) at a time and both will work simultaneously and i also want different zones(like inside,dmz) for both the links ...Is it possible???
chetansharma Fri, 01/02/2009 - 20:15
THANKS
See whats the scenario is there i have 1MBPS ISP line connected to my ASA 5540 and everything like internet web hosting,applications all are working fine,but without disturbing the present scenario i want to add another 2 MBPS ISP line to the ASA 5540 to host another applications of new project.Is it poosible... becoz there is no more port available on asa and if i upgrade ASA with a card 4GE SSM,can both work simultaneously without affecting traffic.
Yes.
Another solution would be if you have a cisco or any switch that can perform a do1q trunk, would be to connect the current 1MPS circuit to a cisco switch and create a specific vlan for that ISP connection. Then when you get the other ISP connection - create and connect it into another vlan.
Then connect the outside of the ASA to the switch and make the switch port a trunk port to the ASA. Then you create a sub-interface on the outside interface of the ASA.
You don't need the 4GE card, BUT if the switch is faulty - you could possible loss both connections.
HTH>
chetansharma Sat, 01/03/2009 - 03:13
Thanks a lot
ok means i can upgrade my firewall with a card 4ge and everything will work fine, i will go for this becoz firewall is in failover(active\standby)..so redundancy is thr.
If u have any suggestion pls go ahead.
victor_87 Sat, 01/03/2009 - 06:11
I would suggest you go for the MULTIPLE_CONTEXT mode on your Cisco ASA, As you mentioned that you are using a 5540 ASA and also running failover, i assume that you either have the Security plus license or the vpn Plus license installed on it.
To the best of my knowledge both these licenses support MULTIPLE_CONTEXT modes.
You can either go for a SSM card for the additional ports or if you want to do some cost saving you can use subinterfaces and VLANS on the ASA, with each subinterfaces lying in a different CONTEXTS serving a completely different set of users or applications.
If you really want to get to the pinaccle of the configuration, you can go ahead and try ACTIVE/ACTIVE failover for the 2 contexts.
for multiple-context condig you can refer :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml
and for Active/Active failover you can refer:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml
Active/active failover has several limitations, read the document carefully before you proceed.
Rate if helpful.
chetansharma Sun, 01/04/2009 - 02:35
i am unable to create sub-inerface on my asa 5540.Failover is active/stand-by.How can i create sunb-interface and vlan in ASA 5540.
victor_87 Sun, 01/04/2009 - 04:04
Both the links i have posted above have resources about creating sub-interfaces on the ASA. It would be better if you read the documents first , understand then and then proceed in the direction you are moving in.
Doing something without understanding what is being done will put you in trouble.
