Firewall Support
Dec 31st, 2008
I have a ASA 5540,and i have one ISP link connected to outside interface and now i want to connect one more 2 mbps another isp line to them is it poosible to connect with the use of extended 4ge ssm card.can a firewall support two ISP lines at a time.
sachinraja Fri, 01/02/2009 - 06:09
  • Red, 2250 points or more
hello chetan
that shouldnt be an issue.. the biggest challenge is on the routing front ! Are you going to use the second ISP line for only a particular user subnet ? The first as primary & second as backup ?? there are too many multihoming scenarios ... If that is the case, I would recommend you to buy a small router which can take these internet links, and do BGP & other advance routing features, and the ASA should do what it is best at (stateful firewalling, IPS, etc)....
I would minimise many configs on ASA, and let it do firewalling to the best of its effort, since no one wants to compromise on security !
Hope this helps..
Raj
chetansharma Sat, 01/03/2009 - 04:07
THanks
See whats the scenario is there i have 1MBPS ISP line connected to my ASA 5540 and everything like internet web hosting,applications all are working fine,but without disturbing the present scenario i want to add another 2 MBPS ISP line to the ASA 5540 to host another applications of new project.Is it poosible... becoz there is no more port available on asa and if i upgrade ASA with a card 4GE SSM,can both work simultaneously without affecting traffic.
