Cisco LMS sending traps : Please advise
Jan 1st, 2009
Please advise why are we getting Insufficient memory traps ?
ALERT ID = 00000S4
TIME = Thu 01-Jan-2009 14:35:37 IST
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 10.10.xx.x
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = MEM-10.10.xx.x/1 [Processor]:InsufficientFreeMemory; 172.20.xx.x [10.10.xx.x]:Unresponsive;
CUSTOMER IDENTIFICATION = ABC
Joe Clarke Thu, 01/01/2009 - 12:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There could be a variety of reasons. what version of DFM is this? If you drill into this alert in the DFM Alerts and Activities Display, what does the underlying memory event say? What type of switch is this? What version of code is it running?
Joe Clarke Fri, 01/02/2009 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
According to this, you only have 5.5% free memory. The default free memory threshold is 15%. If this is normal for this switch, and performance and operations are not be affected, you can increase the free memory threshold in DFM under DFM > Configuration > Polling and Thresholds > Managing Thresholds.
However, if this is not normal, you might want to ask on the LAN switching forum as to what you can do to isolate the memory problem.
