Home Lab - Correct IOS
Jan 1st, 2009
Hi All,
I have just took the plunge and bought my first home lab, as a part of my CCNA studies.
I managed to get my hands on;
2x 2924 Switches
1x 2520 Router
2x 2501 Router
1x 2514 Router
1x 803 Router
3x Ethernet Transcievers
Plus all asscociated cabling for £165.00.
I am goin to swap one of the the 2924 for a 2950. Hoever, I am just wondering what version of IOS I should have on all this equipment, to get the most out of it all.
jrensink78 Mon, 01/12/2009 - 08:47
Definitely a good idea to get a 2950 switch in there. I believe the command line is different on the older switches, and the 2950 command line is what you want to get used to.
Go for a 12.3 IOS on the routers if you can. Should should be able to do pretty much everything except for maybe IPv6.
marcjones84 Mon, 01/12/2009 - 23:20
Excellent, Thanks for the reply guys.
I will be getting my 2950 Switch next week, and then I will look at upgrading my IOS on the Routers.
