ACE 4710 Stickiness Configuration
Jan 1st, 2009
We have the ACE 4710 Ver. A3(2.0) configured and the load balancing is working fine. But we are having problem to keep a user session on one web server. The website is running on IIS, and it's created using ASP.NET. The user session is bouncing between the two load balancing servers. How can we configure stickiness to solve this issue? Or, what are the recommend solutions?
Collin Clark Fri, 01/02/2009 - 06:26
  • Purple, 4500 points or more
Here is an example of a sticky config. This will sticky on source address.
sticky ip-netmask 255.255.255.255 address source WebSeal_Sticky
replicate sticky
serverfarm WebSeal_Farm
Then apply it-
policy-map type loadbalance first-match WebSeal-Virtual-Server-l7slb
class class-default
sticky-serverfarm WebSeal_Sticky
policy-map type loadbalance first-match WebSeal_HTTPS-l7slb
class class-default
Also check out the configuration guide.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/device_manager/guide/dmguigd.html
Hope that helps.
