Maximum memory size for 2800 series routers
Jan 1st, 2009
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
As per this link 2811 routers support 256 MB CF. I know the P/N for 128 CF and it is MEM2800-128CF. What is the Cisco P/N for 256 MB CF? Is it MEM2800-256CF.
Is there a link on CCO giving this P/N MEM2800-256CF for our 2811 routers.
At the moment we are using 1 GB CF from a third party and we are having intermittent problem adding files to this CF after 80 MB only have been used out of 1 GB CF. We get "Failed Sector Write" error
Router#copy tftp flash:
Address or name of remote host []? 172.31.135.98 Source filename []? c2800nm-spservicesk9-mz.124-15.T5.bin
Destination filename [c2800nm-spservicesk9-mz.124-15.T5.bin]?
Accessing tftp://172.31.135.98/c2800nm-spservicesk9-mz.124-15.T5.bin...
Loading c2800nm-spservicesk9-mz.124-15.T5.bin from 172.31.135.98 (via FastEthernet0/0): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
%Error writing flash:/c2800nm-spservicesk9-mz.124-15.T5.bin (Failed Sector Write)
I need to buy some Cisco 256 MB CF and try:
Also see attachment
Overall Rating: 5 (1 ratings)
Sushil Kumar Katre Thu, 01/01/2009 - 20:07
Hi Alphonse,
I did a quick search in the price list and found that MEM2800-256CF= (256MB CF for the Cisco 2800 Series) part number is available for ordering.
However there is no document available on CCO.
I'll suggest, you get in touch with your partner/distributor and ask for a 256MB CF for your router.
-> Sushil
jaregalado Thu, 01/01/2009 - 23:15
these are the part numbers of CF cards available for 28xx series routers:
MEM2800-128CF= 128MB CF for the Cisco 2800 Series USD 700.00
MEM2800-256CF= 256MB CF for the Cisco 2800 Series USD 900.00
MEM2800-64CF= 64MB CF for the Cisco 2800 Series USD 400.00
You must stick to Cisco branded CFs only, anything else is not supported by Cisco.
Regards.
astanislaus Sat, 01/03/2009 - 01:11
Jsmie,
Thsmkd for the info.
My customer is using 1 GB flash from Kingston.
He has problems loading higher version of IOS files into this flash and if loaded fails to boot, etc.
