souvik.mazumdar Fri, 01/02/2009 - 05:00
Hi Andrew,
Thanks for your reply. I just wanted to know the use of this command.
Mark Yeates Fri, 01/02/2009 - 07:10
  • Gold, 750 points or more
The service internal command unlocks many commands for internal testing. Having this configured will allow many undocumented commands that you would not normally see. You really shouldn't use the command without guidance from TAC as there could be some negative consequences on the equipment and/or production network.
HTH,
Mark
souvik.mazumdar Sat, 01/03/2009 - 06:33
Thanks for your response. So we don't have any doc which gives info about the command.
Regards...
Mark Yeates Sun, 01/04/2009 - 14:49
This is an undocumented command and have yet to see any documentation regarding it.
Mark
