Regarding Hide NAT(PAT)
Jan 2nd, 2009
Dear Team,
Whether doing Hide NAT(Hide behind IP or Hide behind Gateway) will automatically add two rules in the rulebase.
For example If someone from internal network want to access external public IP
Internal Network 10.10.10.1/24
External IP:- 1.1.1.1(Public IP)
NAT IP:- 2.2.2.2
Now when the internal network accesses the public IP it will get Hide NATed to the public IP 2.2.2.2--
Will that mean the one more rulebase will get created automatically(because of Hide NAT) which will mean that the external IP (1.1.1.1) can access 2.2.2.2 and then this 2.2.2.2 IP will get NATed to 10.10.10.1
Am I correct?
If yes then will that mean that at a time either internal network can access external IP OR external IP can access internal network.
cisco24x7 Fri, 01/02/2009 - 06:17
  • Silver, 250 points or more
With Checkpoint:
NAT is independent with security rules. You
need to define both "hide" NAT and add security
rules for inside to get to outside. Most
security folks prefer it this way. Always
deny unless explicitly allow.
With Cisco:
by default, inside is allowed to traverse to
outside unless explicitly deny. This is very
insecure.
Either way, with Cisco, once you define
PAT/NAT, inside hosts can communicate
with outside hosts, by default, unless
explicitly denies.
Easy right?
