Not able to access VPN through GPRS network.
Jan 2nd, 2009
I use VPN Client to connect to a remote VPN network (ASA 5510) firewall. I can successfully login but I cannot access any resources (not even ping servers). Other collegues can do this from home by data card. I tried this from XP PCs with same results. I have a Airtel Mobile gprs connect with my laptop at home, on which I disabled all firewall features in order to troubleshoot, I even placed my laptop in DMZ but the results were always the same.
Can I have some help on this please?
Goutam Sanyal Fri, 01/02/2009 - 01:05
Hello Sachin, Which is your problem- Ping or access the resources? Can you checked with another "User ID" from same XP PCs or ISP? If it is working then check your "User ID", where it has given the permit to access the resources or not. Thanks Goutam
sachin.sharma711 Thu, 01/15/2009 - 22:15
Dear Gautam,
i am not able to Ping or access the resources by Airtel GPRS Phone. instead i can Ping or access all the resources by other DATA Card like reliance and Tata by the same user ID.
I am not able not understand the cause.
sachin sharma
Goutam Sanyal Thu, 01/15/2009 - 22:37
Sachin, your collegues can access the same by which ISP's DataCard? The same? If not, then pls ask you ISP to allow the ESP or UDP 500 Packet through your GPRS. If yes, pls post the VPN Log. Thnaks Goutam
