HUM 1.1.1 Interface Utilisation
Jan 2nd, 2009
I am configuring a Poller for Interface utilisation and have an issue with Serial Interfaces which don't seem to have a relevant counter (see attached PDF).
I suspect I have to reconfigure Hum to obtain the relevant info, just where and what ?
Most of the Routers use the same IOS version 12.4(12c).
Joe Clarke Fri, 01/02/2009 - 10:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
HUM 1.1.1 was bad, and should not have been downloaded. You are being affected by CSCsv80038:
Symptom:
Health and Utilization Monitor reports errors for Interface Utilization pollers. The errors are permanent claiming the interfaces have No Such Instance for ifHCInOctets and ifHCOutOctets.
Conditions:
This occurs after upgrading the HUM 1.0.1 or HUM 1.1.1. The interfaces affected will be slower speed (i.e. less than 20 Mbps).
Workaround:
A template for monitoring interface utilization from slower speed interfaces is available by calling the TAC.
