Failed to log accounting packet to any logging destination
Jan 2nd, 2009
Does anybody knows the explanation of the expresion: "failed to log accounting packet to any logging destination"
Any reference to documentation, internet links, etc. helpful to understand if i have a problem or not would be very grateful.
(I have running acs 4.1 in a windows server)
darpotter Wed, 01/07/2009 - 09:10
Sounds like the CSLog service is broken or you're using remote logging and it couldn't reach any of the remote servers.
CSLog has a number of plug-in "targets" eg CSV, remote agent, ODBC etc. If it doesnt achieve at least one success it will generate the error you are seeing.
In short your log data is going into a black hole never to be seen again.
