John Blakley Fri, 01/02/2009 - 07:03
  • Purple, 4500 points or more
Yes and no. :-)
You can log to the router/switch using:
login on-success log
The problem with this is that it logs to the buffer which will eventually overwrite. I would suggest a syslog server if possible. And this line doesn't work if you're authenticating to a RADIUS or TACACS server, it only works if you're using local authentication.
HTH,
John
*please rate if helpful*
