Unity Connection 7.0.1 Simultaneous Subscriber login
Jan 2nd, 2009
We have a redundant UCONN 7.0.1 envrionement. We have been recieving complaints from some users that have a shared mailbox that they are able to simultaneously login into the same mailboxesa dn acheck and clear the same messages, wich results in confustion and duplicated work. I am assuming that this is because they are hitting different servers (one on the sub one on the pub). Is there a way to have the systems cross echck each other during a converstaiton, and or limit the number of users accessing a mailbox regardless of what server they are hitting?
lindborg Fri, 01/02/2009 - 09:03
  • Cisco Employee,
Neither Unity or Connection are designed for multiple users accessing the same mailbox at the same time - neither system "locks" mailboxes so you will always have windows for those types of issues (i.e. someone marks a message read right before another user goes to hear it). This is not a supported scenario in either product line and never has been.
Connection 7.0 does offer dispatch messaging, however, which is designed to provide a better solution for most uses that need "shared" mailboxes - you might want to look into it. In this setup all users have their own mailboxes (with their own notification device configuration etc...) and messages left for specific call handlers can be sent "dispatch" to all users defined in a public distribution list - everyone gets a copy, all their lamps are lit and/or notification devices fire off and all that good stuff. The first user to respond to a dispatch message has it removed from all other user's mailboxes. It's designed for scenarios like support groups where only one person needs to respond to a service call for instance.
