IP SLA Issues
Jan 2nd, 2009
Hi all,
I'm having an issues with a IP SLA I created which is controlling a static route. It works but is a little unreliable.
ip sla 1
icmp-echo 87.85.165.76 source-interface Vlan2 (this is a static host I use)
timeout 20000
threshold 2
frequency 30
ip sla schedule 1 life forever start-time now
Periodically when i run "sh track" it shows last change x minutes ago rather than days. The overall status appears to be "up" however.
Track 100
Response Time Reporter 1 reachability
Reachability is Up
15 changes, last change 00:03:23
Latest operation return code: Over threshold
Latest RTT (millisecs) 39
Tracked by:
STATIC-IP-ROUTING 0
Is there a way I can make this less sentative - I would ideally like it to only declare "down" after 30 secs with timeout of 20000 to rule out a flapping link?
The_guroo_2 Fri, 01/02/2009 - 08:24
mate you have put the frequency 30 ......its in seconds so after every 30 second it will query.....change that and you will be fine
hope it helps
rasoftware Fri, 01/02/2009 - 08:31
Posted by: rasoftware - 244 Fulwood road
Jan 2, 2009, 8:05am PST
Hi all,
I originally had it set to 15 but it seemed worse.
Do I understand this correctly -
Target- icmp-echo 87.85.165.76 source-interface Vlan2
Timeout - timeout 20000
Number of failures - threshold 2
Every x seconds - frequency 30
So every 30 secs, request ping within 20000ms, if two fail (threshold) - declare it down?
I always see to have this line in sh track
MARTIN STREULE Tue, 01/06/2009 - 04:16
Use the delay command in the "track" part of your config:
delay (tracking)
To specify a period of time to delay communicating state changes of a tracked object, use the delay command in tracking configuration mode. To disable the delay period, use the no form of this command.
delay {up seconds [down seconds] | [up seconds] down seconds}
no delay {up seconds [down seconds] | [up seconds] down seconds}
More info:
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_prb_mult_track_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Hope that helps.
Cheers,
Martin
rasoftware Tue, 01/06/2009 - 04:21
Hi Martin,
Thanks I worked this one out - it's been up for 3 days now without reporting a change using the delay up 10 sec down 30 secs.
Stability is key for my config and I only want failover if it been down for a minute or more.
It is much more stable now.
Thanks for the reply.
Pravin Phadte Tue, 01/06/2009 - 06:36
Your Question:
Declare down after 30 seconds:
Command "frequency 30"
Rule a flapping link ?
Commadn " timeout 20000" (not sure that what is defined"
Remove the static route if the link is down more than 30 seconds and not flapping.
The flapping can occur in minutes and you link may be up for 5 min and then again down or may be down in 1 min 2wice.
This works great for me 5 min.
Paramites needed:
num-packets 3
frequency 300
remove
timeout 20000
threshold 2
When the route goes off. This will wait for 5 min down to replace the route.
So if your link flaps in this 5 min it will shift to backup unless it gest 3 packests in 5 min probe.
Once its down. It changes it route.
Now best part it will stay on the other route unless gain it recives prove of 5 min stable 3 packtes from the icmp-echo ip.
so if the link flaps on icp-echo ip provided it will not relace the route. Once the link is stable it will replace the route.
Downtime not more than 5 sec,
But for the first swicth over it depends on the frequency.
do decide about the frequesy you need to set.
Hope this helps
pravin
rasoftware Tue, 01/06/2009 - 07:34
Thanks Pravin,
I think i've cracked it with the 20000ms, freq 30sec, threshold 2.
Adding delay down 30 sec up 10 has prevented the status changing.
I believe if it missing two pings of a very high latency in 60 sec - it then starts count down - so a max 90 sec before failover. This seems to prevent "flapping" of the route due to a few missed pings when the link is really fine.
The sh track now corresponds to the router uptime, before I was getting a status change every 5 mins or so when the link was fine.
Since I have a VPN working over it - this was causing the tunnel to drop etc which is not good for the terminal users behind it.
I will investigate the "num packets" line as this might provide further more accuracy. I suspect my one just sends a single ping each 30 secs rather than 3 which should provide less false positives
georges.merhej Tue, 02/03/2009 - 03:06
Hello Guys,
Do you have any idea on how to clear the "show track" statistics?
MOE#show track
Track 1
Reachability is Up
57 changes, last change 10:14:49
Latest operation return code: OK
Latest RTT (millisecs) 40
Georges
Pravin Phadte Tue, 02/03/2009 - 04:18
hi,
copy the output for show run sla monitor xxx
config t
no sla monitor xxx
check track it will be 0
then paste back the configs for sla monitor 123
