QoS
Jan 2nd, 2009
guys can someone please tell me the diff between the following class-map
class-map KK
match ip precedence 3
class-map KK
match precedence 3
is it same or it different whats the logic behind these two command.....now one more thing
what the difference
class-map match-all KK
class-map match-any
class-map KK
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Fri, 01/02/2009 - 09:09
"guys can someone please tell me the diff between the following class-map
class-map KK
class-map KK
match precedence 3
is it same or it different whats the logic behind these two command"
Don't believe there's a functional difference, although I recall the syntax changed between different IOS versions. Also recall the later IOS might accept either syntax. As to their logic, both will match against IP packets with IP Precedence 3.
"what the difference
class-map match-any "
-all makes for an "and" condition if there are multiple match statements within the class-map. I.e. class match will be true only if all match statements true
-any makes for an "or" condition if there are multiple match statements within the class-may. I.e. class match will be true if any match statement true
mlund Mon, 01/05/2009 - 01:16
  • Silver, 250 points or more
match ip precedence, matches ipv4 only.
match precedence, matches both ipv4 and ipv6.
/Mikael
