Phantom aliases in LMS 3.1
Jan 2nd, 2009
Under RME, Devices -> Device Management -> Alias Devices, I have a phantom alias. When I select the RME device in the left pane and press the show alias devices button, I get the message "No Devices Available" in the right-hand pane where the alias devices should be listed. Is there a way to fix this?
Joe Clarke Fri, 01/02/2009 - 10:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can contact the TAC, and they can walk you through the procedure to remove the phantoms from the database directly.
