01-02-2009 10:15 AM - edited 03-04-2019 03:18 AM
We have some gateways AS3400, some 3550 and two gateways 3500.
I was trying to remove some crashinfo from the bootflash, the I performed?
router#delete bootflash:<file>
After this command (as normal) the files I deleted appeared taged as deleted.
I got very surprised when I tryed to use the squeeze command and the command wasnt there =0.
That leads me to the question...
How can I flush the deleted files from the bootflash without the squeeze command (please dont say I need to reboot the gateway :( )
01-02-2009 10:29 AM
Hello Luis,
Cisco devices have different filesystems and not all of them need the squeeze operation.
see
http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a00800a7515.shtml
if your devices have B filesystem the erase command is available but it will delete everything so you need before to upload what you want to restore later
Hope to help
Giuseppe
01-02-2009 11:05 AM
Hello Giuseppe,
First of all, thank you for your reply, saved me a lot of time.
So I guess theres nio other way, I would need to use the erase command and recopy the files I need from TFTP.
Aight, thanks again for your reply.
Happy new year
