Can Netflow collect statistics on layer2 interfaces?
Jan 2nd, 2009
I have enabled netflow on a 6513 running 12.2(33)SXH2a. Right now it is collecting statistics for layer3 interfaces only. Can Netflow be configured to collect statistics for layer2 interfaces?
Overall Rating: 5 (1 ratings)
letsgomets Fri, 01/02/2009 - 13:45
Curious... what type of information are you trying to capture in netflow on a L2 interface?
cchughes Fri, 01/02/2009 - 15:22
I'm concerned about seeing server to server flows on the same subnet/vlan. Will a L3 vlan interface do the trick?
Richard Burts Sat, 01/03/2009 - 15:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chris
If the server to server flows are on the same subnet/vlan then the servers communicate directly with each other - from a layer 3 perspective. (frames do come in one layer 2 switch port and exit another layer 2 switchport - so in a layer 2 perspective the 6500 does see them) From a layer 3 perspective the 6500 does not see that traffic. And NetFlow reflects what the router/switch sees at layer 3. So I do not believe that it is possible to see what you want with NetFlow.
Rick
